Not getting any response from diagnostics...
Maybe I'm not quite understanding how to make this work. I'm trying to see string commands from and to my autopatch switcher. I have enabled device notifications, and added 5001:2:0 as the only item in the list of devices to get/send string commands. I am currently connected to my master, and when I push a touchpanel button, I am watching the string response (a variable I created) in debugger mode, but I don't ever see lines populate in the Diagnostics Output Bar. I have disabled my firewall software just in case.
    vegastech wrote: »
    You can't use system 0 for notifications. You have to use the actual system number.
    In your other thread you are using SEND_COMMAND instead of SEND_STRING when sending data out to the switcher.
    Thank you! On both counts. I figured out the send_string item 60 seconds before I saw your post! I gotta stop doing this programming sporadically.
