MVP8400 Connection Probs after WakeUp
Hi
I'm using a MVP8400 with newest Firmware on it. Inside there is a older Wireless Card with only WEP Security.
If the Panel goes to Sleep for many hours, sometimes after WakeUp the Panel i see there is a connection from Panel to the AP, but the Panel doesn't connect to the AMX System. (DHCP and fix IP the same.)
After a complet reset with batt out of the MVP and reboot, the connection to the System is fine.
News: In the setup/wireles settings i open the security windows "simple" and then hit "save". after that it connect again
Is the Panel damaged?
thanks
John
