Iridium Bugs
I have tried Iridium HD today and it works good, but I think I found or I am confirming a few bugs:
1) No pop-up page driven by code.
2) No pop-up page timeout from TP4.
3) No system variables support from TP4 (Time, Date from SETUP)
4) No Link status support . The green link icon that shows when a panel is linked to the master.
All the above is supported by TPControl. Any ideas? Thanks.
  • Jimweir192Jimweir192 Junior Member
    Pop-up Pages work for me, what commands are you using that don't work?
    I've not tried the page timeout, but if you contact the developer they can advise if this is supported / when they can implement.
    System variables don't work, but you can overcome this in code by sending the Master Time as variable text. I understand that the next version will work with system variables.
    Again, I do this from code without any difficulty.
    I think there are a few differences between tpcontrol and iridium, personally I like the gesture lists in iridium for browsing selections - and this fits with the users expectations of how an apple interface should work.
