Using NXA-AVB/ETHERNET
Can I use the IPad instead of Modero touch panels to talk with the NXA-AVB/ETHERNET ?
    udi wrote: »
    Nope,
    here's the description from the website.
    OVERVIEW
    The NXA-AVB/ETHERNET Breakout Box facilitates the installation and distribution of video, data, and audio to Modero touch panels located up to 200 feet (60.96 m) from the AVB box. This unit accepts either Composite or S-Video from standard video devices. The NXA-AVB/ETHERNET also acts as a signal converter. It is designed to take normal wiring from the system and, in turn, translate the incoming audio/video data over CAT-5 cable directly to the Modero Touch Panel.
