AXB-REL8S+ / 230
I'm using an AXB-TEMP and AXB-REL8S+ /230 and NI-700 to control a home clim system.
my problem is that no relay output switch on or off when sending command. the communication between NI-700 and axb-rel8s is ok , if I force an output from relay device I receive the notification that channel pushed and released but when I send an ON[100:1:0, 1] to device no activation and no notification recived.
My question is: does this device required some special programmation for outputs.
Many Thanks for help
You should try the channels 9-16 to switch the relays.
It works as required.
