Cannot compile projects with Duet modules
I think I've run into this before but cannot remember what I did to fix this. And since I found out just now that our company no longer has tech support I'm on my own to remember.
If I comment out all duet modules in a project, they compile just fine.
Does anyone know why duet modules won't compile? I think it has something to do with where the SNAPI file is located but can't remember if this is correct.
e
e
Regardless of the wisdom or lack of it in the pay-for-support policy, at some point you have to wonder if it isn't just worth $100 a month to not have to waste extra hours of labor on stuff like this. What's your time worth?
this is a bad thing in that two of the modules exist on in Duet Form. ( A Pool controller and the iWeather that talks to the AMX color T-Stats) I can obviously rewrite the weather module using the non-duet version and kluging it to talk to the T-Stats. The pool controller is a bit different in that I'd pretty much have to reverse engineer the protocol.
What makes this even worse is that I probably have 30-40 systems that exist in the same state. That'll teach me to trust using Duet modules. (if what you say is true...)
