Has anyone used Startech USB to Serial cable (ICUSB232) to control DIRECTV Receiver?
Has anyone used Startech USB to Serial cable (ICUSB232) to control DIRECTV Receiver? and How is it?
Where would you plan to load that driver, into the DT box or into the NetLinx?
There are various utilities out there that will show you the VID/PID of USB devices attached to your computer. The first one that a google search turned up was http://www.nirsoft.net/utils/usb_devices_view.html.
If you plug the adaptor in question into your computer and fire up that utility, you should be able to determine whether it's likely to work.
