Axcess to netlinx
Previously in axcess programming if you had 6 (number doesn't matter could be any number) identical devices you could use a variable i.e selected_camera, in your code you could them use selected camera = 5 and in your push statement you have
send_string selected_camera,"$01,whatever"
where selected_camera transmitted out on port 5 or whatever port selected_camera =
How do you achieve this in netlinx,
any help greatly apprecited.
You then use the index to point to which device to send too.
define_device (* RS232 *) dvCamera1 = 3:1:1 // Axcent Slave Frame Port 2 dvCamera2 = 4:1:1 // Axcent Slave Frame Port 3 dvCamera3 = 5001:1:1 // NI Port #1 dvCamera4 = 5001:2:1 // NI Port #2 dvCamera5 = 5001:3:1 // NI Port #3 dvCamera6 = 5001:4:1 // NI Port #6 dvTp = 10001:1:1 define_variable volatile dev cameras [] = { dvCamera3, dvCamera2, dvCamera1, dvCamera4, dvCamera5, dvCamera6 } volatile integer selectcamera [] { 21,22,23,24,25,26 } define_event Button_event[dvtp,selectcameras] { push: { stack_var integer k k = get_last (selectcameras) send_string cameras[k], "'DO THIS COMMAND'" } }The trick to remember here is everything is based upon what position in the array you put it.
Hope this helps
Will give it a try.
