DirecTV Cinema Questions?
Since it's near impossible to get the same answer from two different directv employees, I thought I would see if anyone here is familiar with DirecTV Cinema: I have a client with one HR24 and 3 H24s. They are set up for whole home DVR service, and can view/record shows from any box. However, they cannot view DirecTV Cinema channels (1000, 1101, etc.) on the H24s, only the DVR. If a show is selected from the DVR to record/download, it is then accessible via the Recorded List on any box. Is this how this always works? I was hoping that with the new boxes and software that DirecTV Cinema (OnDemand) services would be available on all boxes. FYI, this home has a SWM Dish, MRV service added, DECA network inserter at the structured panel, and single lines run to each box, including the DVR. No ethernet, no phone lines. All boxes have been reset today, and also setup has been run again, with naming all boxes. Thanks in advance for any info!
So what you describe makes sense and is likely not to change in the life of the current hardware. Or new firmware might eventually improve it.
- Chip
