WebUpdate and Software History 2.1
I believe there is a slight problem with the WebUpdate program and Software History 2.1 (listed as Software in the WebUpdate program) It looks like whatever flag is set to indicate a program is installed isn?t getting set because after it downloads and installs Software History 2.1 it still wants to install it again. I?ve tried it on three different PCs and get the same results so I believe it?s the Update program and not my particular setup.
Joe
Joe
Ditto - same here. Problems may not be limited to Software History alone - Thomas started a thread a week ago regarding Web Update and potential problems with other downloads.
http://www.amxforums.com/showthread.php?t=708
It is definitely a problem. The solution for now, don't use until AMX fixes it.
