Samsung LED IR
Working on a project with 4 Samsung LED Displays. I've spent hours trying to get the IR to work on two of the units. It seems like the emitters only work out of the shell. Any tips or tricks appreciated. Samsung UN55C6400 and a UN26Cxxxx.
David Groves
DG Sales and Service
David Groves
I have actually had really good luck with the attached IR file and placing the emitters on the back of the TV. You can get the emitters to hit the IR receiver by putting them directly behind the IR window or putting them inside one of the holes that the TV stand normally hooks into.
The only other variable I can think of is that I never use AMX emitters. I have had too many failures with them (and they are expensive) so I stick with Xantech emitters for everything.
