IR Edit with remote central files
HI
I would like to know if I use (copy and paste) the hex code from an IR file on remote central.com in a new file in IR edit, will work with NI controler?
I need LCD 3D Sony panel and I don't find it in AMX Data base...
    Nearly all will work. You'll know when you paste them in, as when you CONTINUE, it will tell you if the code is a valid code IREDIT understands.
    There's ways to fix ones that don't work, but it's not something you want to do... more involved than you'll want to get.
