Kramer Protocol 3000
FYI
Kramer have new products out using Protocol 3000, but from experience and searching the documentation it doesn't state that the default baud rate for Protocol 3000 is 115200, not the 9600 used in Protocol 2000.
You can switch between 2000 and 3000 but the baud rate also needs to be swapped on the master / control device
Hope this saves someone some time!!
