HEX->IRedit->Not working
I have downloaded the the .ccf file with the ir codes from Audio Request. I'm interested in the zone1, zone2...zone4 codes. I have confirmed the codes work from the pronto to the Request, I also confirmed they are in RAW format using IR code doctor.
0000 006a 0009 0000 0040 0021 00c0 0061 0080 0041 0060 0061 0020 0021 0060 00e1 0020 0041 0020 0021 0020 00c1
I then entered the hex codes into IREdit where they cease to function. Any ideas of things to try at this point? I do not have the AMX IR learner. Is their a way to change the amplitude of the IR ports on a NI controller? I have looked in the AMX-PI and did not see anything. Most of the IR codes work in the IRL file that I obtained from the AMX website a few of them did not and using the method I mentioned above i was able to get them to work. I just have these last 4 hold outs.
This also seems like as good of time as any to ask a few academic questions that have been on my mind regarding IR and AMX
It is my understanding from reading the AMX-PI that CTON and CTOF commands only affect the timing of codes sent using the XCHM method... or does it govern all IR sent through that port? Ok i guess its only one question:) and BTW the CTOFF I am aware of that and don't believe its my issue i have tried both ways both wired and with an emitter.
Thank you for any help you have to offer in this department.
DATA_EVENT [dvREQUEST_IR]
ONLINE:
SEND_COMMAND dvREQUEST_IR,"'SET MODE IR'" //SET IT TO IR
SEND_COMMAND dvREQUEST_IR,"'CAROFF'"
SEND_COMMAND dvREQUEST_IR,"'XCHM-0'"
SEND_COMMAND dvREQUEST_IR,"'CTON',3"
SEND_COMMAND dvREQUEST_IR,"'CTOF',2"
If you PULSE and IR code the pulse width is the global value set by SET_PULSE_TIME (by default it’s .5 sec)
I rarely ever use PULSE when dealing with IR. I stick with SP for almost everything except for volume which I normally use a TO.
The IR code you posted looks pretty short. Are the working IR codes that short also?
On the bright side a second look at the AMX-PI reviled those SP commands you mentioned, they should come in handy
And yes, the output of an AMX IR port is a bit weaker than many other IR devices, and no, there is no way to turn it up higher. If you have a very long wire run on very small gauge wire, that could be your issue; but I have successfully run over a hundred feet on 22 ga. ... not sure you could pull that off on CAT 5 though. What I would do is hook an emitter directly to the back of your controller and temporarily get the device right there to test. That would rule out malformed IR right away. If you are already in the same cabinet, try an new emitter before you go too nuts. I've had that solve the problem many times and save me a lot of chasing after gremlins that didn't really exist.
Thank you all for the replies and ideas!
