Extract .jar and .tko file from amx controller
I tried to extract code form amx controller but got only source code file .I found that source file contain only .axi and .axs file but i have not found .jar & .tko file . is it possible to extract .jar & .tko file from controller ?
Any idea ?
  • I don't want to play the nitpicker, but.... ;)
    "Build with Source" will build an archive of "source codes" only (.src).
    It will contain "classic" source like axs and axi, but not .jar, .tko (also not the source of a module), .tkn or .lib(SystemCalls).
    There's no way to directly save "Everything" from Studio to the master. A way may be to link all files into a workspace, do an "Export Workspace Files to Go" to get an axw archive, and then e.g. send it to the master's CF disk by ftp.
    One could zip up the entire project and FTP it to the master. That'd be nice.
    However, this would assume that the programmer/intaller would have done so in the firsts place. It has been my experience with taking on orphaned or bad-relationship projects that nothing of this sort ever happens. I almost always end up reprogramming.
