AMX software and MacBooks
Hello,
I'm thinking of switching to a MacBook, and I'm wondering what you Mac users are successfully using as a Windows emulator that provides a trouble-free (!) environment for Studio, IR Edit, TPD3 and 4 etc.
I'm running Win7 under Parrallels on a MacBook Pro with 4MB of memory. I probably could use some more memory but can't afford it. For the most part there is no problem running anything. Every now and then every thing comes to a halt and a reboot of the entire system resolves the problem. I believe I have everything running from Studio, to TPD4, TPD3, Panel Builder, Panel Preview, KP Design, KP Builder, VA (not that I use it much), PI, IREDIT, TP Control, etc. The only thing that won't work is Landmark but that has nothing to do with the Mac.
I've only found the need to run it natively while editing live SVGs. (Spinetix)
For AMX stuff it works fine.
Just don't bloat your windows with unnecessary programs and keep it to a minimum. That way you shouldn't need more than 2GB for your windows installation. (Memory wise)
Just make sure you get a macbook with sufficient memory and a good graphics card.
Normal boot up is always windows unless I decide to boot up in MAC then I hold down the "option" key. I don't like MAC but it is handy to have especially when you have to setup a customer's MAC to do something. I can practice on my MAC so I don't look like such an idiot when I'm working with theirs. Otherwise I'm somewhat of a MAC hater and using these MACs has only solidified that hate. Yes, I know hate is a bit harsh but MAC users have no problem hating PCs with out just cause.
We've added Savant to our lineup (using for smaller jobs where we would have spec'd C*tron) and so now I have a MacBook for that, plus my old PC laptop for everything else. It just seems to make sense to consolidate.
Thanks a ton for the advice.
"PC guy" is different from "Windows guy." Depending on your definition of PC (EFI + bios emulation counts? EFI alone counts?), Macs are PCs now.
I'm a "PC guy" but the only place Windows is used in my life is at work. At home, I run Gentoo Linux. Still need to see if AMX's software will run on Wine, just haven't had time to get around to it.
