CSG-SIP 500-544 Connection problem
in AMX Hardware
Hi
I have a problem about csg siip gateway..
I have 2 mvp 5200i and 1 csg-544 gateway this is our first try to make this..
We have connected to server by ip phone port as you say and then we did the settings of sip setting of panels..but there is a wrong or missing thing we cant do..we didnt connet the panels to the server..
our settings is in panel is:
proxy adress is:our gateway ip adress default 192.168.69.1
port number :5060 they say this is default but i couldnt see where can we chane it?
stun adress :blank
local domain:blank
username:Admin
Password:1988
Im not sure about this settings
and my 2nd question..we making two user in server extension 6000 and 6001 for our two 5200i but they are unavailable in server what cen we do about that...our tlelphone information is not so good can you explain how we connect the server ni and our two mvp 5200i
Thnx for your replys..
stun adress :blank
local domain:blank
username:Admin
Password:1988
Admin/1988 is to administer the gateway settings, users, etc...
Pg 38 of the user manual gives you some more details on how to create extensions. Whatever extension/password you give for each user is the user/pass you should use on the panel.
http://www.amx.com//techdocs/CSG-500.544.580.OperationReferenceGuide.pdf
Regards.
