R4 error message
Whenever I load the new R4 remotes it gets to the end and I get an error. It does not load the last 4 or 5 items. The error reads Tranfer Aborted - Error opening file on master. Requested file does not exist or is invalid.
What does this mean or what do I need to do to upload all the files?
This. Sometimes there is a problem with the file system being dirty, and a smart transfer will fail. Clearing the user pages with the latest firmware will also clean up the file system.
Will this be fixed any time soon? Its my understanding that its also happening on MVP5200i as well. I am currently upgrading a project with numerous R4s that have intense graphics, and having to clear all pagesand then do a full transfer is a huge time sink. My guess is that it can't be fixed in firmware and that a modification to TPD is required, which will likely take many months. Am I correct?
Paul
We found the R4 to be too slow to be acceptable in painting buttons with our standard button and channel icon set (which included over 1000 bitmaps). We reduced it to about 500 in total and got a really large performance boost. We tried again with about 300 and couldn't see enough more improvement to merit the work to do further reduction in bitmaps.
Note also that the "smart transfer" also takes a while to figure out what to transfer, so even if it worked reliably, the time savings would be trivial. And since a "smart transfer" usually fails (and the larger the transfer, the more likely to fail), the clean start transfer is MUCH faster...
