Device Mapping bug in Netlinx Studio
Has anyone else noticed that the device mapping seems to be broken in the later versions of Netlinx Studio?
The devices defined just don't show up. Which forces me to define custom device mappings which have to be manually updated if the system is changed.
Or am I missing some new setting in the options that fixes device mapping?
Dude that is huge. I knew about the bug, but did not know about the workaround. I just tested this and BAM, there they are. Thanks a ton!
On a similar vein, I have had projects where I had to custom map every device, then was able to go back a week later and map them normally, with no idea why it works some times and not others. I just gave up and do whatever I need to do to make it load.
Enough already with the hidden settings and "automatic" crap. Put all this stuff in some config setting, or even an old-fashioned INI file. I am more than quite fed up with auto-configurations that are broken that you can't fix manually. If you absolutely must hide the settings, your system has to be bulletproof, period, no exceptions.
The IDE needs a serious revamp, not just bugfixes. It's so outdated that everytime I open a modern IDE tears of happiness come out. And tears of sadness when I open NS. They need to step up their game and keep their programmers happy. Else I predict a serious nerdriot.
