List Box
Hi guys,
I've read "Dynamic List Box Table Example" from help of TP4, and I've done some practice following this tutorial.
But I've the following doubts:
1) what means the statement:
send_command Keypad,"^LVC-2,4"
the comment says:
//Sets the column number (4) to display in the view with address 2
so, what is the "view"?
2) How can I select or emphasize a single row of a List Box widget?
3) I know that the list box doesn't give feedback, but if I set column type as "channel", can I have some kind of event wich can be managed by an handler?
Thanks in advance for your tips
Regards
Nicola Dicosmo
p.s.
I past there the tutorial:
DEFINE_DEVICE
Keypad = 11001:1:4
Keypad2 = 11001:2:4
KeypadMusic = 11001:10:4
DEFINE_EVENT
BUTTON_EVENT[Keypad,5]
PUSH:
//Deletes any existing data list at address 1
SEND_COMMAND Keypad, "'^LDD-1'"
//Creates new 5-column data list at port 1, address 1 named "my music"
SEND_COMMAND Keypad, "'^LDN-1,1,5,my music'"
//Specifies column types for the data list at address 1 starting at column 1
SEND_COMMAND Keypad, "'^LDT-1,1,0,0,0,0,3'"
//Adds rows to the data list at address 1
SEND_COMMAND Keypad, "'^LDA-1,0,01,The Shins, Chutes Too Narrow, Kissing the Lipless, "10,1"'"
SEND_COMMAND Keypad, "'^LDA-1,0,02,The Shins, Chutes Too Narrow, "Mine''s Not a High Horse", "10,2"'"
SEND_COMMAND Keypad, "'^LDA-1,0,03,The Shins, Chutes Too Narrow, So Says I, "10,3"'"
SEND_COMMAND Keypad, "'^LDA-1,0,04,The Shins, Chutes Too Narrow, Young Pilgrim, "10,4"'"
SEND_COMMAND Keypad, "'^LDA-1,0,05,The Shins, Chutes Too Narrow, Saint Simon, "10,5"'"
SEND_COMMAND Keypad, "'^LDA-1,0,06,The Shins, Chutes Too Narrow, Fighting in a Sack, "10,6"'"
SEND_COMMAND Keypad, "'^LDA-1,0,07,The Shins, Chutes Too Narrow, Pink Bullets, "10,7"'"
SEND_COMMAND Keypad, "'^LDA-1,0,08,The Shins, Chutes Too Narrow, Turn a Square, "10,8"'"
SEND_COMMAND Keypad, "'^LDA-1,0,09,The Shins, Chutes Too Narrow, Gone for Good, "10,9"'"
SEND_COMMAND Keypad, "'^LDA-1,0,10,The Shins, Chutes Too Narrow, Those to Come, "10,10"'"
SEND_COMMAND Keypad, "'^LVC-2,4'"
//Updates the view at address 2
SEND_COMMAND Keypad, "'^LVU-2'"
