Cameras not responding
Hey Guys i'm new AMX programer and it's my second thread on AMX forum and sorry for my stupid question but really i need help to go with...I have a master controller as NI4000 and 4 NI700 as slave ,every slave is controlling 4 cameras ,now cameras are moving using positrack controller ,but i cant move them just to view and zoom for images . so my questions are :
1: where the problem can be ?
2: the actual program that control the cameras exist in NI700 or in the main processor NI4000 ?and normal what code the NI 4000 should handle ?
3: if the problem is in the software so i need programming from the begining,so if i have a touch panel to controll all area and cameras ,how can i handle this code ?
Thanks you all and i appreciate your help guys.
Are you asking for help to fix code you have written or for help writing the code required?
If the former you will need to post some examples and a clearer explanation of what is wrong.
If the later then you will need to hire someone.
Cheers
Mush
We can view the output of the cameras and zoom in/out ,cameras are not moving that is the problem (cameras are fixed to positrack )
so i just need a push with how can i start programming not the code but the general concept , and does Ni4000 must hold the main code for controlling cameras ? or just defining Ni700,touch panel and camera's controllers ?
Thanks for your reply i know it's not clear but i need some backup ,really thank you guys.
Have you tried connecting the camera to a PC and talking to it directly?
Troubleshoot.
