Flickering buttons
I have a system with three Ni3100 controllers M2M.
I have testet all the systems by themselves, but after updating URL-lists and connecting to the network all buttons with channel feedback startet to flicker. They seem to switch rapidly on and off.
What may cause this?
  • Jimweir192Jimweir192 Junior Member
    I'd suspect you have 2 sets of code both trying to update the same button feedback ie one ON and one OFF.
    It will be in your code, are all 3 Masters running the same code and accessing the same TP or multiple TP?
    Run diagnostics and turn device notifications on. That will tell you if there is conflicting feedback ... though it sure sounds like it. Beware, that kind of continuous feedback flutter can bring the whole master down if left unfixed.
