Anyone using Wyrestorm?
Specifically I was looking at their HDMI/IR over cat5 solution. Anyone use this brand before? Any good?
http://www.wyrestorm.com/50m_CAT5e_Cat6_HDMI_Extender_with_IR_p/ext1t132-33.htm
Thanks!
--John
Thanks!
--John
The one I linked has IR passing capability which I like. The distance we'll need to go is about 12-15 meters. I'd run a regular HDMI cable, but a category cable will be more versatile, and easier to retro.
Thanks.
We have used the Wyrestorms on one job so far. They worked beautifully over cat6 (2) where the AudioQuest units failed miserably or continued to have sync issues. You power them at the display, as opposed to at the source equipment, which I thought was a little odd...you know, amping a crappy degraded signal only gives you a crappy less degraded signal..but it worked well, so I'm happy with them.
