Keypads Offline and Online Occasionally
in AMX Hardware
Greetings,
I have a system with 14 MET7 keypads. After observing diagnostics, I notice that a few of them go offline for a few seconds and then come back online. They don't do it simutaniously. Is this to be expected for noramally-functioning keypads?
Thanks.
Thanks.
Just brainstorming....
Line 1 (11:12:23):: ClockMgr: Setting system time to - TUE JUL 27 11:12:26 2010$0A
Line 2 (11:12:52):: Connected Successfully
Line 3 (11:12:52):: CIpEvent::OnLine 0:4:103
Line 4 (11:12:52):: Exiting TCP Read thread - closing this socket for local port 4
Line 5 (11:12:52):: CIpEvent::OffLine 0:4:103
Line 6 (11:32:07):: CIpEvent::OffLine 106:1:103
Line 7 (11:32:13):: CIpEvent::OnLine 106:1:103
Line 8 (11:32:52):: Connected Successfully
Line 9 (11:32:52):: CIpEvent::OnLine 0:4:103
Line 10 (11:32:52):: Exiting TCP Read thread - closing this socket for local port 4
Line 11 (11:32:52):: CIpEvent::OffLine 0:4:103
Line 12 (11:52:52):: Connected Successfully
Line 13 (11:52:52):: CIpEvent::OnLine 0:4:103
Line 14 (11:52:52):: Exiting TCP Read thread - closing this socket for local port 4
Line 15 (11:52:52):: CIpEvent::OffLine 0:4:103
Line 16 (12:12:25):: ClockMgr: Setting system time to - TUE JUL 27 12:12:28 2010$0A
Line 17 (12:12:52):: Connected Successfully
Line 18 (12:12:52):: CIpEvent::OnLine 0:6:103
Line 19 (12:12:52):: CIpEvent::OnLine 0:4:103
Line 20 (12:12:52):: Exiting UDP SNMP Read thread - closing this socket for local port 6
Line 21 (12:12:52):: CIpEvent::OffLine 0:6:103
Line 22 (12:12:52):: Exiting TCP Read thread - closing this socket for local port 4
Line 23 (12:12:52):: CIpEvent::OffLine 0:4:103
Line 24 (12:15:53):: CIpEvent::OffLine 112:1:103
Line 25 (12:15:59):: CIpEvent::OnLine 112:1:103
Line 26 (12:28:07):: CIpEvent::OffLine 109:1:103
Line 27 (12:28:13):: CIpEvent::OnLine 109:1:103
Line 28 (12:32:52):: Connected Successfully
Line 29 (12:32:52):: CIpEvent::OnLine 0:4:103
Line 30 (12:32:52):: Exiting TCP Read thread - closing this socket for local port 4
Line 31 (12:32:52):: CIpEvent::OffLine 0:4:103
Line 32 (12:46:53):: CIpEvent::OffLine 101:1:103
Line 33 (12:46:59):: CIpEvent::OnLine 101:1:103
Line 34 (12:52:52):: Connected Successfully
Line 35 (12:52:52):: CIpEvent::OnLine 0:4:103
Line 36 (12:52:55):: Exiting TCP Read thread - closing this socket for local port 4
Line 37 (12:52:55):: CIpEvent::OffLine 0:4:103
Line 38 (13:12:28):: ClockMgr: Setting system time to - TUE JUL 27 13:12:31 2010$0A
Line 39 (13:12:52):: Connected Successfully
Line 40 (13:12:52):: CIpEvent::OnLine 0:4:103
Line 41 (13:12:53):: Exiting TCP Read thread - closing this socket for local port 4
Line 42 (13:12:53):: CIpEvent::OffLine 0:4:103
Line 43 (13:24:07):: CIpEvent::OffLine 101:1:103
Line 44 (13:24:13):: CIpEvent::OnLine 101:1:103
Line 45 (13:32:52):: Connected Successfully
Line 46 (13:32:52):: CIpEvent::OnLine 0:4:103
Line 47 (13:32:52):: Exiting TCP Read thread - closing this socket for local port 4
Line 48 (13:32:52):: CIpEvent::OffLine 0:4:103
Line 49 (13:52:07):: CIpEvent::OffLine 113:1:103
Line 50 (13:52:13):: CIpEvent::OnLine 113:1:103
Line 51 (13:52:52):: Connected Successfully
Line 52 (13:52:52):: CIpEvent::OnLine 0:4:103
Line 53 (13:52:52):: Exiting TCP Read thread - closing this socket for local port 4
Line 54 (13:52:52):: CIpEvent::OffLine 0:4:103
Sent from my HERO200 using Tapatalk
Current reading is 94.9, peak is 99.5. Seems high!?
Running timelines? Stuff in the define_program section?
In my case, there are no master-to-master connections.
Thanks.
The NI-x100's are capable of 404 MIPS (million instructions per second) and the 700/900's 304 MIPS (I think). Under normal operation they shouldn't be pushed to anywhere near this. Generally when you see usage that high it's an indication of some code sitting in an infinite loop.
Also, remember that the 6N's use 2 addresses each. Make sure you don't have any address conflicts.
One of the system modules has a bunch of IF/THEN in the define_program. I'm going to try commenting out that module.
The processor here is an NI-2000.
This from our head engineer:
In case you’re not already familiar with this: The CPU USAGE command only gives valid number when the system is started with the “reboot heap watch” command in TELNET. Otherwise it will always give the same numbers which are a snap shot taken at boot time. This mode is turned off at next normal reboot.
The numbers are obviously going to vary based on what your system is currently doing. If you run the CPU USAGE command several time you’ll see the numbers fluctuate. Having a max of 99% is not uncommon. You average of 60% is pretty normal.
Here is what my test processor happened to be at when I looked: (System was handling some traffic but not much.)
CPU usage = 9.71% (30 sec. average = 51.85%, 30 sec. max = 99.96%)
Here are my numbers during a reboot:
CPU usage = 96.61% (30 sec. average = 21.10%, 30 sec. max = 96.61%)
Is that still true for the latest firmware? Our systems report back system health and load info stats, including cpu utilization, to our RMS server. When the systems are under load it appears to be correctly reporting the increased usage. These are all booted into 'normal' operating mode.
Hmmmm?
I'm still stuck on the whole CPU useage thing. AxLink is pretty rock-solid when its set up right. Here's an out-of-left-field question: Are you using any Duet modules? and if so, What's your Duet memory set to? You might try jacking it up a bit. I've had a few flaky systems mysteriously 'get better' by jacking up the Duet mem a bit.
Just at thought.
I don't know, but RMS may manage the activation of the monitoring. My test here now looks like it isn't active on the current firmware.
Idling after normal reboot:
CPU usage = 99.97% (30 sec. average = 92.07%, 30 sec. max = 99.99%)
This would indicate it is NOT actually monitoring, the value reported is always the same.
Unless it happens inside the RMSEngineMod its not doing it. Everything else has been rolled internally.
*Edit
Even within the RMSEngineMod when there's a vanilla system running code which was all rolled internally it appears to function fine.
*Edit (again)
Just contacted the TS guys here and they're not aware of any requirement to reboot with the heap watch flag. They're getting in touch with some of the engineering boffins over at AMX HQ for confirmation. I'll post the results when I hear back.
