How to CUE this
20 microphone units, every microphone send ONn if it going online and send OFFn when going offline.
I need a Wait list of max 5 positions.
Position: [1][2][3][4][5]
I allway`s need to send the name of the first device in the wait list if some position changed in the wait list like below.
microphone online
ON12
ON16
ON9
Wait list need to change to: [ON12],[ON16],[ON9],[4],[5]
Send string online = ON12
microphone online
ON6
ON18
Wait list need to change to: [ON12],[ON16],[ON9],[ON6],[ON18]
microphone offline
OFF16
Wait list need to change to: [ON12],[ON9],[ON6],[ON18],[5]
microphone offline
OFF12
Wait list need to change to: [ON9],[ON6],[ON18],[4],[5]
Send string online = ON9
microphone online
ON1
Wait list need to change to: [ON9],[ON6],[ON18],[ON1],[5]
How to handle this?
Toon
microphone online
ON12
ON16
ON9
microphone online
ON6
ON18
microphone offline
OFF16
microphone offline
OFF12
microphone online
ON1
How to handle this?
Toon
DEFINE_DEVICE dvTP = 10001:1:0 dvMicThingy = 5001:1:0 DEFINE_VARIABLE VOLATILE CHAR cMicQueue[5]; DEFINE_FUNCTION AddToMicQueue(INTEGER cMic) { cMicQueue = "cMicQueue,cMic"; } DEFINE_FUNCTION RemoveMicFromQueue(INTEGER cMic) { STACK_VAR INTEGER nLocation; STACK_VAR CHAR cTemp[5]; cTemp = cMicQueue; nLocation = FIND_STRING(cMicQueue,"cMic",1); cMicQueue = GET_BUFFER_STRING(cTemp, nLocation - 1); GET_BUFFER_CHAR(cTemp); cMicQueue = "cMicQueue,GET_BUFFER_STRING(cTemp, LENGTH_STRING(cTemp))"; } DEFINE_FUNCTION INTEGER GetNextMic() { RETURN GET_BUFFER_CHAR(cMicQueue); } DEFINE_FUNCTION CHAR SearchMicQueue(INTEGER cMic) { IF (FIND_STRING(cMicQueue,"cMic",1) > 0) RETURN TRUE; RETURN FALSE; } DEFINE_EVENT BUTTON_EVENT[dvTP,1] //MIC NUMBER 1 BUTTON_EVENT[dvTP,2] //MIC NUMBER 2 BUTTON_EVENT[dvTP,3] //MIC NUMBER 3 BUTTON_EVENT[dvTP,4] //MIC NUMBER 4 BUTTON_EVENT[dvTP,5] //MIC NUMBER 5 BUTTON_EVENT[dvTP,6] //MIC NUMBER 6 BUTTON_EVENT[dvTP,7] //MIC NUMBER 7 BUTTON_EVENT[dvTP,8] //MIC NUMBER 8 BUTTON_EVENT[dvTP,9] //MIC NUMBER 9 BUTTON_EVENT[dvTP,10] //MIC NUMBER 10 BUTTON_EVENT[dvTP,11] //MIC NUMBER 11 BUTTON_EVENT[dvTP,12] //MIC NUMBER 12 BUTTON_EVENT[dvTP,13] //MIC NUMBER 13 BUTTON_EVENT[dvTP,14] //MIC NUMBER 14 BUTTON_EVENT[dvTP,15] //MIC NUMBER 15 BUTTON_EVENT[dvTP,16] //MIC NUMBER 16 BUTTON_EVENT[dvTP,17] //MIC NUMBER 17 BUTTON_EVENT[dvTP,18] //MIC NUMBER 18 BUTTON_EVENT[dvTP,19] //MIC NUMBER 19 BUTTON_EVENT[dvTP,20] //MIC NUMBER 20 BUTTON_EVENT[dvTP,21] //MIC NUMBER 21 { PUSH: { IF (SearchMicQueue(BUTTON.INPUT.CHANNEL) == TRUE) RemoveMicFromQueue(BUTTON.INPUT.CHANNEL) ELSE AddToMicQueue(BUTTON.INPUT.CHANNEL) } } BUTTON_EVENT[dvTP,100] // SELECT NEXT MIC { PUSH: { SEND_STRING dvMicThingy,"'ON',ITOA(GetNextMic())" } }I get the online/offline mics info from the RS232 buffer and store them in a variable like: CHAR nMic[3] // hold last online mic and CHAR dMic[3] // hold last offline mic
These are numbers like this: nMic = '001'
After that I need to manage a queue for these mics like I wrote before.
I will do some testing using your code, thanks for that.
Toon.
Here is adding the mics to the queue from an RS232 Buffer, assuming Carriage Return or something between messages.
DEFINE_VARIABLE CHAR cMicBuffer[255]; DEFINE_START CREATE_BUFFER dvMicThingy, cMicBuffer DEFINE_EVENT DATA_EVENT[dvMicThingy] { STRING: { STACK_VAR CHAR cMsg[20]; // ASSUMING: "'ON001',13" // ASSUMING: "'ON021',13" // ASSUMING: "'OFF021',13" // ASSUMING: "'OFF019',13" WHILE(FIND_STRING(cMicBuffer,"13",1) > 0) { cMsg = REMOVE_STRING(cMicBuffer,"13",1); SELECT { ACTIVE (FIND_STRING(cMsg,'ON',1) > 0): { REMOVE_STRING(cMsg,'ON',1); AddToMicQueue(ATOI(cMsg)); } ACTIVE (FIND_STRING(cMsg,'OFF',1) > 0): { REMOVE_STRING(cMsg,'OFF',1); RemoveMicFromQueue(ATOI(cMsg)); } } } } }
