AXB-DTMF+
edgelitoc
edgelitoc Junior Member
Has anyone programmed AXB-DTM+, during OFF HOOK it does not dial a number. I hear a dial tone but can't dial after that.
  • svTech
    svTech Senior Programmer
    Is your code sending the DIAL Send_Command after the Off-Hook Button_Event? I use the DTMF+ box quite a lot (yes, still) although we don't do much dialing out. But, generally, using Send_Commands, it always has seemed to work when I trigger it manually. What is the code you are using to control the DTMF+ box?
  • edgelitoc
    svTech wrote: »
    my code has a button event with a certain channel is on..Once a i had place a call to DTMF from an extension phone i need to press 1 or 2 on the telphone to page, once the corresponding channel has detected my programm will trigger the presets on DSP then you can page to a certain zone.
