VOIP panels and integration
davec
davec Junior Member
Hello there!
I`ve been asked to see if i can integrate any of the AMX VOIP panels with the Shoretel VOIP telephone system. I`ve read quite alot of things about the SIP gateway, does the panel need this to talk to other vendors?
Do the panels support RFC 3261?
Any information would appreciated
Dave
  • jtalley
    jtalley AMX Engineering
    The /i/ panels all have a SIP stack. MVP5200i, NXD500i, 700Vi, etc...
    While 3rd party gateways are not officially supported, you shouldn't have any trouble connecting to one. Usually if you have an issue, its with the value-add features provided by the other gateway.
    I believe others have connected to Cisco gateways. I have never heard of Shoretel, so I can't say for sure.
  • davec
    davec Junior Member
    I am still having problems with connecting this directly from the panel to the Shoretel, and in-directly through the CSG.
    I can get the Shoretel system to call the panel via the CSG but cant get the panel to call out of the CSG. Our Shoretel expert is looking into why this could be.
  • jtalley
    You could verify registration by checking voicemail for the extension on the CSG. I've not setup gateway<->gateway comms before so I can't say what needs to be done there.
    You might poke around the Asterisk forums and see if anyone has integrated Shoretel and Asterisk. It would be very similar to what you are trying to do.
