Can a function return an array?
I can't get one to.
This compiles...
Line 68 (17:12:24):: GetVariableSize - Error Tk=0x0100
Line 69 (17:12:34):: GetString - Error 1 Tk=0x0000
Line 70 (17:12:34):: CopyString (Reference) - Error 2 S=0x0000 D=0x1033
Line 71 (17:12:34):: GetString - Error 1 Tk=0x0000
Line 72 (17:12:34):: CopyString (Reference) - Error 2 S=0x0000 D=0x1033
This compiles...
DEFINE_VARIABLE
LONG ar2[12][12]
DEFINE_FUNCTION LONG[12][12] array_test()
LONG ar1[12][12]
INTEGER bleh; INTEGER bar
for(bar=1;bar<=12;bar++)
for(bleh = 1; bleh <=12; bleh++)
ar1[bar][bleh] = bleh
RETURN ar1
BUTTON_EVENT[dvTP, 1]
PUSH:
ar2 = array_test()
I don't like this semi colon: the semi colon after bleh means INTEGER bar isn't being defined which breaks the code. Otherwise it should work I think since the help files say only structures and class (class?) won't work.
You can return an array but its limited to a single dimension. See [thread=5843]this thread[/thread].
@vining
The compiler treats the semi colon's as a statement terminator so it shouldn't be causing any issues.
I guess you're right. I was thinking end of line termination and I know it's screwed me up after function definition but if I took the time to look at the for loop in the code I would have easily realized my thoughtless observation couldn't possibly be correct.
As long as the array isn't too big...
There are several Netlinx functions that use this technique such as ASTRO_CLOCK, FILE_DIR, FILE_READ, and GET_IP_ADDRESS to name a few.
You can then use the RETURN value as some sort of pass or fail flag if so desired.
Ah thanks. I didn't see this one in my searches.
Also not a fan of the pass by reference way, especially when I'm trying to keep the function in an include instead of the main.
Edit:
Modules can pass multi-dimensional arrays. Re-usability crisis averted...
To make your test example work correctly...
Change this:
DEFINE_VARIABLE LONG ar2[12][12] [b]DEFINE_FUNCTION LONG[12][12] array_test()[/b] { [color=red]LONG ar1[12][12][/color] INTEGER bleh; INTEGER bar for(bar=1;bar<=12;bar++) { for(bleh = 1; bleh <=12; bleh++) { ar1[bar][bleh] = bleh } } [color=red]RETURN ar1[/color] } DEFINE_EVENT BUTTON_EVENT[dvTP, 1] { PUSH: { [b]ar2 = array_test()[/b] } }To this:
DEFINE_VARIABLE LONG ar2[12][12] [b]DEFINE_FUNCTION array_test(LONG ar1[][])[/b] { INTEGER bleh; INTEGER bar for(bar=1;bar<=12;bar++) { for(bleh = 1; bleh <=12; bleh++) { ar1[bar][bleh] = bleh } } } DEFINE_EVENT BUTTON_EVENT[dvTP, 1] { PUSH: { [b]array_test(ar2)[/b] } }After you press button 1 each of the 12 rows in ar2 will be filled with the numbers 1-12.
You can move the array_test() function to any include file that you want and it will work the same way.
Tech Note 662 (SPLIT_STRING) is another example of a function that fills in a double dimensioned container that is passed into it.
HTH
room1 = parse_csv('room1.csv')
foo = parse_csv('foo.csv')
where parse_csv returns a two dimension array
I could like you say above and just let the include complain about the variable not being defined; It still works, but that compiler warning bugs me.
parse_csv('foo.csv', foo)
Your original function that I modified can be placed anywhere, in any include or in main. There shouldn’t be any kind of scope issue. There shouldn’t be any warnings or errors. I too am dead set against warnings and I won’t accept them.
If you can give a more specific example I’d be happy to look at it. Or if you just want to drop it that’s fine too.
Bottom line though, a function can *return* a double dimensioned array as SPLIT_STRING demonstrates. It just can’t be the RETURN value but it will accomplish the same exact thing.
Sorry. I see what you're saying now. For some reason I thought the variables (the global and the function's) had to have the same name, but you used ar2 and ar1. That'll work fine then.
But yeah, if you leave a variable name out of an include that needs it somewhere, it won't compile, but if you have that variable defined in your main, your main will compile, including the stuff in the include.
