Control a Device Dialog
Hello all.
Simple frustration here: Message(s) to Send text field and the String Expressions check box.
Perhaps I just don't get it, but I cannot figure out how to format what I want to output. I have read the help page on many occasions, and its explanation leaves me more confused. Probably the easiest way to explain this would be an example. I want to send:
"This is my string" with a 0x03 (CR, $03) on the end.
In Java, a simple concat would work (with a cast for the CR):
"This is my string" + (char) 0x03
or
"This is my string\r" - for the escape sequenc
I have tried:
"'This is my string',$03" with the String Expressions checked
"This is my string",$03 with the String Expressions checked
'This is my string,$03 with the String Expressions not-checked
All seem to fail.
(FYI - Baud and other comm parameters are set correctly and intentionally.)
What is the right answer? Thanks in advance!
Matt
