TPD4 Button disabled state
nicoladicosmo
I'm working with a general button, If it is set as Disabled (General Properties select 'Yes' from the drop-down) can I assign to it a diferent image? and if yes, How?
I've to change the button type to have this?
ND
ND
nicoladicosmo wrote: »I'm working with a general button, If it is set as Disabled (General Properties select 'Yes' from the drop-down) can I assign to it a diferent image? and if yes, How?
ND
Should be possible with the following commandsend_command panel,"'^BMP-<vt addr range>,<button states range>,<name of bitmap/picture>'"
send_command panel,"'^BMP-500,0,silly.png'"
if you want to do multiple buttons you can by doing xxx.xxx so 500.515 would be button 500 to button 515.
0 = all state
1 = off state
2 = on state
This can also be found in the PI.
Not positive if this also works if the button is disabled, but I imagine it should. -
Hi all,
thanks for your answers -
