XOR Comparison binary Checksum
Hey,
Controlling a Beyerdynamic MIX 10 NG2 and it wants a checksum on the end... yay.
From the manual:
"The check sum results from a vertical XOR comparison of the individual command bytes in the binary system."
There's an example and I understand how I manually calculate it... but how would I do this in NetLinx? Theres no hex to binary command? The other option is to calculate all the checksums manually for all the different codes I am going to need... which I would prefer to avoid.
User Manual: http://asia-pacific-india.beyerdynamic.com/shop/media//usermanual/MIX10NG2_BA_E_A5.pdf
From the manual:
CHAR cChk
cChk = cBYTE1 BXOR cBYTE2 BXOR....BXOR BYTEn
SEND_STRING dvSerial,"cBYYTE1, cBYTE2, ..., cBYTEn, cChk"
a function to calculate the checksum may be
DEFINE_FUNCTION CHAR BXORcheckSum(CHAR sBytes[]) { STACK_VAR CHAR cChk STACK_VAR INTEGER nX FOR(nX=1;nX<=LENGTH_STRING(sBytes);nX++) { cChk = cChk BXOR sBytes[nX] } RETURN cChk } ... DEFINE_VARIABLE CHAR sMyString[] = { $01,$02,$FF } CHAR cMyChkSum ... cMyChkSum = BXORcheckSum(sMyString) SEND_STRING svSerial,"sMyString,sMyChkSum"
