Downgrading a 3000 for faster boot times
in AMX Hardware
I'm trying to get a project done but the long boot times of the 3000s are driving me crazy.
I am not using (nor plan to use) any duet modules and would be happy to lose all the web stuff, in order to speed the patch/compile/download/reboot/test cycle.
Can I safely load old firmware in the 3000? If so, which kit file(s) do use?
________
HZ ENGINE
________
HZ ENGINE
I'll give it a try.
________
DAIHATSU NAKED
It's perfectly safe to revert to the last non-duet firmware, not only will it significantly speed up your boot time but also cpu performance will improve, i've had my home system running 2.32.148 for the past year without any problems.
