Vantage InFusion Commands
Does anyone know what the LED command is? I know the format as follows:
LED <button vid> <color1 (0-255)> <color2> <color3> <offcolor1> <offcolor2 (0-255)> <offcolor3> <blinkrate (FAST/MEDIUM/SLOW/VERYSLOW/OFF)>
But I am not sure what color code and blinkrate are.
Thank you.
  • truetrue Junior Member
    The protocol is documented in the InFusion programming software helpfile.
  • kennyannkennyann Junior Member
    True:
    Thank you for your input. The only thing I see in the vantage help file is the one line protocol under Host commands. It does not give me any other discription or details. I need to know the code for their color on their keypads and the what is the blink rate.
    Thank you.
