APR3-PRT3 Printer Module
Has anybody dealt with integrating a Paradox Alarm System? I seem to be having some trouble to get it to work with an ni700..
The system is connected to the APR3-PRT3 Printer Module, which then is set up for Home Automation mode (all done by the guys from Paradox). This enables it to send the different zone statuses via serial. I have used a portion of Matlab code directly on the printer module to check the format of the output and also to confirm all the serial settings and it works 100%. I've also done the same with the ni700, feeding in the output that I recieved from the printer module via Matlab, and it also works 100%.
However, when I connect the two together, I can't get the ni700 to recieve anything! I'm sure most likely a fundamental problem between the two, as individually they are working. Being relatively new to this, is there anything about serial communication that I might be doing fundamentally wrong? A portion of the very simplified code is shown below;
//Start Code
DEFINE_DEVICE
//dvNI700 = 5001:0:0 //default setting for controller
dvPROJECTOR = 05001:1:0 //RS232 communication used for projector
dvSERIALCOMMS = 05001:2:0 //RS232 communication paradox
dvIR = 05001:3:0 //IR port out
etc..
DEFINE_START
CREATE_BUFFER dvPROJECTOR,PROJECTOR_BUFFER //PROJECTOR COMMUNICATIONS
CREATE_BUFFER dvSERIALCOMMS,SWITCH_BUFFER //PARADOX SYSTEM COMMUNICATIONS
SET_PULSE_TIME (3) //Set up pulse time for IR
SEND_COMMAND dvPROJECTOR,'SET BAUD 19200,N,8,1,485 DISABLE' //Set up projector for interface
SEND_COMMAND dvSERIALCOMMS,'SET BAUD 9600,N,8,1,485 DISABLE' //Set up PARADOX
etc..
DEFINE_EVENT
DATA_EVENT[dvSERIALCOMMS]
STRING:
SWITCH_BUFFER = "SWITCH_BUFFER, DATA.TEXT"
SELECT
ACTIVE(FIND_STRING(SWITCH_BUFFER,"71,48,48,49,78,48,50,52",1)):
ON[dvSWITCH1,1]
SWITCH_TEMP = REMOVE_STRING(SWITCH_BUFFER, "71,48,48,49,78,48,50,52",1)
(* SECOND TWO ACTIVE STATES ARE FOR TEST ONLY
ACTIVE(FIND_STRING(SWITCH_BUFFER,"71,48,48,49",1)):
ON[dvSWITCH1,1]
SWITCH_TEMP = REMOVE_STRING(SWITCH_BUFFER, "71,48,48,49",1)
ACTIVE(FIND_STRING(SWITCH_BUFFER,"$00,$00,$01",1)):
ON[dvSWITCH1,1]
SWITCH_TEMP = REMOVE_STRING(SWITCH_BUFFER, "$00,$00,$01",1)
WAIT 50
OFF[dvSWITCH1,1]
//CHECK PARADOX ZONES IF NIGHT/AUTO MODE ON
WAIT 10
IF(PARADOX_FLAG|PARADOX_FLAG_2)
//REQUEST ZONE STATUS
SEND_STRING dvSERIALCOMMS, "82,90,0,0,1,13" //REQUEST ZONE 1 STATUS
  • pfrpfr Junior Member
    Sorry, that last section of code should read;
    DEFINE_PROGRAM
    WAIT 10
    A couple of things to try:
    1) Make sure the cable is correct. Check out the first 2 questions in the forum FAQ.
    http://amxforums.com/showthread.php?t=4085
    2) The baud rate SEND_COMMANDs should be moved from DEFINE_START to the ONLINE: handler of the DATA_EVENT for your serial devices. The RS-232 ports may not be ready to accept a command when DEFINE_START triggers. If you wait for the ONLINE event you?ll know the ports are ready.
    HTH
    Indeed, I need to recheck the cable! I've also subsequently moved the send_command to the online segment of the data_event. With an incorrect cable, would it still be able to send commands but perhaps not recieve them?
    Thanks!
    pfr wrote: »
    Depending on how the cable is pinned it's possible, yes.
    Ah, cable was wired with additional pins. Hopefully that was the problem!
    One other thing. Since you are filling your own buffer in the STRING: handler you don't need the CREATE_BUFFER in DEFINE_START. You normally use one or the other but not both. If you use both methods you'll end up with twice the amount of data.
