Dynamic Images w/o path/file?
Is it some how possible to pull an MJPEG stream if I can't provide a path and/or filename? I have some new cameras made by HAI that don't require or have a path or filename and they expect you to get the stream by the IP:Port but I can't seem to make it work with for a TP's dynamic image or a Synollogy Surveillance Station since their entries won't accept anything that doesn't use a filename.
Network Path Information
While AMX strives to bring to the market innovative features such as support for Motion JPEG, at points we have to work through the different ways manufacturers implement standards. In the case of streaming network cameras/servers, manufacturers are using somewhat different syntax for requesting Motion JPEG streams from their networked cameras and servers.
For example, many networked cameras/servers are accessed using a regular HTML browser, and the camera/server is serving up an HTML page with a video window being a part of the page. For Dynamo, however, the panel needs to access only the M-JPEG stream, not the entire HTML page served by the camera/server by default.
Depending on the camera/network video server type you are using, you may need to consult product documentation, or if necessary, contact manufacturer's technical support. In general, however, what is being sent to the camera/server in the path is a CGI call that may have additional parameters based on the feature set of the camera/server and the syntax the manufacturer requires. What follows are examples for some of most popular manufacturers.
Note: Like with any other type of equipment AMX controls, manufacturer's documentation and customer support are the most reliable ways of obtaining information on the device's communication protocol/syntax. This can also help you fully utilize optional features available on that specific device.
However, at times it can be difficult to get the needed information with respect to the protocol/syntax of a particular camera/server. One way to work around this is connecting to your networked camera or video server using an Internet browser that captures the location or path to the stream. An example of such browser is Mozilla FireFox. Using the browser you can go to your network device's IP address, left click on the streaming image and select Copy Image Location.
You can download a free version of FireFox at www.mozilla.org.
If there is an escape sequence that I could use, cool but if not no big deal I'll just use the cameras somewhere where TP display isn't a requirement unless I use an HAI TP but I don't see that happening any time soon (knock on wood). I did also talk with one of HAI's engineers and they simply don't have a path or filename for their video stream just IP:port and that's it. I've also check it all out in Wireshark, opening the HTML page and opening the stream and there's nothing I could see other that what they said so if there's no way around the filename requirement on the AMX side, then there's no work around.
I didn't realize a path was absolutely required and thought leaving it blank would have worked, but I assume you tried that and had no luck. Have you tried using a '/' or '/index.html' just to have something there? If it works in a browser with http://192.168.1.100:8080 then it should work with a panel. Does the documentation mention what the default path is? If so, maybe you can use that. Have you considered that a port is being blocked rather than a path being wrong?
Paul
Our test showed that you must have something in the filename parameter to get dynamic images to work. The PATH is in fact optional. You must understand that when you pass
host path filename
that the panel will impute a forward slash ( / ) between each item. If there is nothing in PATH, it adds only one slash between host and filename. You can't put all the url into HOST, but you can put all the path and filename in FILENAME. You can't put the filename in PATH and leave filename empty. You can split up the path into both PATH and FILENAME on some convenient / point.
I don't know if there's a way to get your URL. You could try adding a / as the filename. It may or may not mess up the connection, but might work. It does in browsers... multiple trailing / don't stop a url from working.
Yeah, http://192.168.xxx.xxx:8008 works just fine in FireFox.
192.168.x.x:8008 could be anything from 192.168.x.x:8008/index.html to 192.168.x.x:8008/index.php
Use something like the Firebug extensions for FireFox to figure it out.
Question, how do you delete a resource created through code? Is there a way to switch to Dynamo from code? Although I haven't looked that hard I didn't find an answer to either question.
Although I tried the RAF, BMF and BBR commands the only one I really had success with was the RMF. I would also then need the RFR, PPX and then call the pop up again but I didn't really get into that to see which order and which combinations worked best. I've always found the dynamic image commands to be temperamental.
This particular cameras doesn't allow for a user/pass to can access to the stream (stupid) but I left in the %U & %P w/o value just cuz I originally created the resource incorrectly with values.
