Xantech CC12 IR IN
NI3101 IR Controlling a Xantech CC12. (Needed a couple big Relays for some lights)
Wired Direct from the IR Out on the NI to the IR IN on the Xantech.
Nothing. IR Confirm doesnt even Blink.
Have nor used one of these Xantch boxes in quite some time...
Do I need to set my IR output up differently for going direct into the Xantech? Do I need to use a Xantech IR Receiver and a Flasher off the AMX?
I've had the same problem before. The quickest fix was to use an emitter out of the NI and flash a dinky link connected to the Xantech relay.
