INTERCOM making a lot of Noise
in AMX Hardware
Hi,
I have received a complaint from one of our customer saying that there is disturbing noise which is produced when you communicate between two intercom devices.
In this site we have 15 METECOM and two 8" TP.
The noise is produced when one TP is communicating with another METECOM and the noise is pretty bad. This doesn't happen always but most of the time it happens and it is actually annoying since the TP is in reception and lot of noise is heard there.
I have also experience thed same problem when i was doing a villa project. There the communication is between two 5" TP.
What do you think is causing this. Could it be the network issue. The switch used there is 1GBps and so I cannot blame it on the network.
