Compatibility: Windows 7, 64 bit, etc.
I know various combinations of this scenario have been talked about here before, but I'm wondering if anyone has recent experience.
We're looking to upgrade our laptops to 64-bit machines (i7 quad core) running Windows 7 64 bit. Will Studio and TP4 run nicely under "XP mode"? Is "XP mode" even necessary? Any issues you know of?
Thanks in advance for any anecdotes.
Tpdesign3 appears to work OK on my Windows 7 64bit machine. When does it fail?
Kind regards,
Steve
OLDesign doesn't even open - I get the attached message.
It appears that you can't even download it anymore from the link you referenced. I guess you've tried running it in XP or even Win 95/98 compatibility mode?
Kind regards,
Steve
Anyway, yes - I've tried running under all of the options. One thing I did not do, was install it under those options - I'm curious if that'll make a difference.
A free download from MS.
Even better, thanks for those. I shall play.
Hi there,
In the same vein as above. I am running TP4 on a Windows 7 64bit machine. It appears that everytime I download a panel file or open an old panel file it says unable to install fonts and instead uses the default font. I've had to resort to loading the file on an XP machine and copying the font over to the 7 machine for it to work.
Any ideas?
Colin
Every time I get a new laptop I copy the font folder from my old computer and then use these fonts to install the ones that are missing. I really wish that TPD4 would give a list of all of the missing fonts instead of "try - fail - install - repeat"
I would like to 2nd this idea. It would be tremendously helpful!
--John
I've taken to backing up the workspace with winrar instead.
I also have not gotten TPs to work with the USBLan stuff, but fortunately I could fight the TPs long enough to get a wifi connection to a master, and update the firmware that way.
No problems with TPD4 as far as I know.
I have had these issues before but we recently moved all the computers to windows 7 professional, and haven't had an issue connecting with USBLan since. (did install it in compatibility mode though, maybe you should try that as well?)
Exporting and importing workspaces works fine for me as well. Am running x64.
It could be other drivers that are messing with your amx drivers. For example pronto and amx drivers mess each other up sometimes.
At one point I had installed all software for
Amx, c-tron, vantage, lutron, rti, pronto, c4. A few IDE's as well. And my drivers were all messed up. I have been able to install all that now without any issues though.
Missing in TPD4 when you leave XP for newer Windows is the little check box on the RESOURCE MANAGER file manager that lets you choose to overwrite duplicate filenames. This widget isn't legit in Vista or 7, so it is missing. And there is nowhere else in the system you can access it... per AMX support.
This means all your replacement bitmaps get named COPY OF [name] and don't replace the originals. And if you delete the originals and rename the COPY OF's, you find that they aren't assigned to the buttons anymore. You MUST use SEARCH AND REPLACE, but then you have to live with images with wacky names.
I keep an XP machine specifically for such things.
