Recalling Structure elements with for loops
I am trying to send multiple 232 strings to a lighting device in order to send a preset where there are a total of 4 loads to control. I am however having a problem with my structure elements, and I think it's how I created/named my structures. Basically, I have 4 zones that I am trying to recall by using a FOR loop, and because of (I believe) how I created the structure, I don't think it will ever work. I've got a total of 2 Structures:
5 arrays, each with a name, 4 zones, and lights in each zone with intensity and fade time values.
I feel like the for loop will provide me with the ability to expand this to however many presets I need, so that's why I'm trying to use it. Thanks.
STRUCTURE _Light //light load setting structure
INTEGER nIntensity
INTEGER nFadeTime
STRUCTURE _LightPresets //structure to call 4 zones of lighting loads
CHAR sPresetName[15]
_Light nZone1
_Light nZone2
_Light nZone3
_Light nZone4
And I then create 5 instances of the Presets Structure:
DEFINE_VARIABLE PERSISTENT _LightPresets uLightPresets[5] //5 presets to store lightingThis way, I have 5 instances, each with a name, 4 zones, and in each zone, 2 integers for storing current level and fade time. My problem comes in when I am trying to send a string using a for loop, like so:
BUTTON_EVENT[dvTPLight,30 //this is merely for testing purposes at this point
PUSH:
local_var integer i
FOR(i=1;i<=4;i++)
SEND_STRING dvLight, "'FADEDIM,',itoa(uLightPresets[1].nZone(i).nIntensity),',[1:1]',$0D,$0A"
SEND_STRING 0, "'FADEDIM,',uLightPresets[1].nZone(i).nIntensity,',[1:1]',$0D,$0A"
I am sending the string twice, once to the device and again to device 0, again, for debugging purposes. When I try to compile, I get this message:
ERROR: RSB, Rev2.axs(811): C10235: Symbol [NZONE] is not a member of STRUCTURE [_LIGHTPRESETS]I understand that the compiler doesn't like that I am trying to call a structure element with a variable, since the structure element in question is not already part of an array, in which case, I think it would work fine. How can I adjust my structure to allow for this type of coding? I was working on something like this, but couldn't get it working, since I can't specify values in the DEFINE_TYPE section:
DEFINE_TYPE
INTEGER nIntensity
INTEGER nFadeTime
STRUCTURE _Zone //light zone holds a single _Light Structure
_Light nZoneLight
STRUCTURE _LightPresets //structure to call 4 zones of loads
CHAR sPresetName[15] //15 bytes
_Zone[4] = {1,2,3,4}
Ultimately, my structure needs to look like this:5 arrays, each with a name, 4 zones, and lights in each zone with intensity and fade time values.
As the compiler says, you cannot substitute part of a variable name with ()... these generally denote a function call, or indicate execution order when doing math.
Try this:
STRUCTURE _Light //light load setting structure { INTEGER nIntensity INTEGER nFadeTime } STRUCTURE _LightPresets //structure to call 4 zones of lighting loads { CHAR sPresetName[15] _Light nZone[4] } DEFINE_VARIABLE PERSISTENT _LightPresets uLightPresets[5] //5 presets to store lighting BUTTON_EVENT[dvTPLight,30 //this is merely for testing purposes at this point { PUSH: { local_var integer i FOR(i=1;i<=4;i++) { SEND_STRING dvLight, "'FADEDIM,',itoa(uLightPresets[1].nZone[i].nIntensity),',[1:1]',$0D,$0A" SEND_STRING 0, "'FADEDIM,',uLightPresets[1].nZone[i].nIntensity,',[1:1]',$0D,$0A" }That should work.
P.S.
There is a chance that you can flood the communication lines with this and lock-up or drop messages. You could move to a timeline or create a queue if this becomes a problem.
