Using GLH command
Thomas Hayes
I'm playing around with the GLH command so I can adjust the upper bargraph level depending on the source for the volume. I have tried but so far I am not able to get it to work. It appears to be a pretty straight forward command but BG on my TP never seems to adjust to the upper level I assign it using the command. Is there somewhere special I should have this command located ? right now I have it in the online event section for the TP. Any help would be appreciated.
I am loading a touch panel to verify functionality here. I will let you know in a few minutes if it works.
Just tested and it works using the following command: "'^GLH-1,100'" via diagnostics.
