IR edit
Thomas Hayes
Hi everyone,
Does anyone know if you can create your own template in IR edit and import IR codes to your template. I'm trying to create a very univrsal configuration for the major functions that I use for such devices as a DVD/VHS combo.
Well, if you look into the \program files\common files\AMXshare\Databases directory you will find an Access database file named AMXTemplate.mdb
It would probably take a bit of research but I assume that you could "clone" and existing template and make changes in order to save it as a new template.
Unfortunately, I would suspect that as soon as AMX released a new version of IREdit, they would overwrite your custom modifications.
You could probably assign really high keys to your records and then export your tables to a comma-delimited text file. Delete everything in it except your entries and then you could import the files back into the database after AMX clobbered it.
Danny -
Thomas,
Using Access I was able to do the things that I described in my previous reply, but it requires that you go into each of the tables and make entries.
It isn't pretty but it did work. I had wondered if the AMX guys had some kind of program that let them do the dirty work but after looking at the database I'm not so sure. They have a couple of temp tables defined in the database that make it handy to cut, paste, and edit but it is still a lot of work.
Danny -
I take a very simple approach towards IR templates...I put the standard stuff (transport controls, numerics buttons, power) in the usual 1-28 channel slots, and everything else between 29-100. Then I just map the panel buttons directly to the function. So if the menu code on my DVD is IR channel 32, I make the panel button channel 32 as well, and use BUTTON.INPUT.CHANNEL to send the IR pulse. If I change IR files, it's just a matter of touching up the button channels, and it's something the guys in the field can do (especially with older systems that still have a G3) without me running out to the site.
The template system was a good idea, but there are just way too many files out there now that almost entirely ignore it. Rather than edit every one to make it conform to a template, I just do as I have describedl; it's easier, and I don't feel like I am losing anything. -
Thanks Guys
After I started to modify a standard template I noticed problems. I've started to move all the main commands into standard positions like Dave mentioned. Seems the easiest way to go. I ran into problems when I tried to modify a Hitachi DVD/VHS combo and realized that it has discreet (play, stop, pause, etc) commands for the DVD and VHS.
