Firmware v3.50.40 Bad telnet command!
in AMX Hardware
Someone tried to start spy from telnet? My controller after this command hangs (AxLink, RS232, Drop TCP session).
Reboot helps. But!
Reboot helps. But!
Hmm...
which command are you speaking of?
I?m not sure why Kim says it?s a bad command, I?m pretty sure it?s just a tool.
I just tried it on a master and got the 'unknown command' result. It must be on newer firmware or something.
When I run it here with a NI-3100 running v3.5.430 it drops it's TCP connection to the touch panel. Haven't got any RS-232 or AxLink devices attached to this one at the moment so I can't confirm whether they drop as well.
This is a sample output:
>spy Spy Diagnostic -------------- Report frequency = 10 seconds Interrupt clock frequency = 100 ticks per second To stop call 'spy stop' > NAME ENTRY TID PRI total % (ticks) delta % (ticks) ------------ ------------ ---------- --- --------------- --------------- tExcTask 0x3a1314 0x997c38 0 0% ( 0) 0% ( 0) tJobTask 0x3a222c 0xdd5a30 0 0% ( 0) 0% ( 0) tLogTask logTask 0xdd8d88 0 0% ( 0) 0% ( 0) tNbioLog 0x3a3898 0xddc920 0 0% ( 0) 0% ( 0) tShell0 shellTask 0x1008ac8 1 0% ( 0) 0% ( 0) tWdbTask wdbTask 0xff41b0 3 0% ( 0) 0% ( 0) tSpyTask spyComTask 0x1da0a50 5 0% ( 0) 0% ( 0) tErfTask 0x2b0ef4 0xde0340 10 0% ( 0) 0% ( 0) ti2cTxTask i2cTxTask 0xda0260 50 0% ( 0) 0% ( 0) ti2cRxTask i2cRxTask 0xda2510 50 0% ( 0) 0% ( 0) tNetTask netTask 0xde8d60 50 0% ( 0) 0% ( 0) tXbdService 0x39ce7c 0x100c770 50 0% ( 0) 0% ( 0) tZeroConf-ht 0x241fa8 0x1bad668 50 0% ( 0) 0% ( 0) tFtpdTask 0x2ed0c 0xfedd10 55 0% ( 0) 0% ( 0) tSSHTelnetSv StartSSHTeln 0x1114260 55 0% ( 0) 0% ( 0) tTelnetSvr StartTelnetS 0x112b6d8 55 0% ( 0) 0% ( 0) tDhcpcStateT 0x321be4 0xfe6db8 56 0% ( 0) 0% ( 0) tDhcpcReadTa dhcpcRead 0xfe9420 56 0% ( 0) 0% ( 0) tAxlinkRX StartAxlinkR 0x10ef538 90 0% ( 0) 0% ( 0) tAxlinkTX StartAxlinkT 0x10eb758 91 0% ( 0) 0% ( 0) tICSPIPTX StartICSPIPT 0x10cc828 97 0% ( 0) 0% ( 0) tICSP232TX StartICSP232 0x10d74c8 97 0% ( 0) 0% ( 0) tICSPIPRX StartICSPIPR 0x10d0fd8 98 0% ( 0) 0% ( 0) tICSP232RX StartICSP232 0x10dd9b8 98 0% ( 0) 0% ( 0) jReference H 0x12a924 0x1987318 98 0% ( 0) 0% ( 0) ICSPTCP27 StartICSPTCP 0x1c4bc80 98 0% ( 0) 0% ( 0) ICSPTCPRx27 StartICSPTCP 0x1d64b08 98 0% ( 0) 0% ( 0) ICSPTCP31 StartICSPTCP 0x1d67e88 98 0% ( 0) 0% ( 0) ICSPTCPRx31 StartICSPTCP 0x1c366e0 98 0% ( 0) 0% ( 0) tCypherConnR TaskCypherCo 0x1b63160 99 0% ( 0) 0% ( 0) tCypherI2CRx TaskI2CRx() 0x1b66f18 99 0% ( 0) 0% ( 0) tTffsPTask flPollTask 0xde3ce8 100 0% ( 0) 0% ( 0) tConnectMgr StartConnect 0x10ad928 100 0% ( 0) 0% ( 0) tIPConMgr StartIPConne 0x10e1798 100 0% ( 0) 0% ( 0) tMsgDispatch StartMessage 0x10a49d8 101 0% ( 0) 0% ( 0) tConfMgr StartConfigu 0x10e5578 101 0% ( 0) 0% ( 0) tRouteMgr StartRouteMa 0x10b1708 102 0% ( 0) 0% ( 0) tNotifyMgr StartNotific 0x10b54e8 102 0% ( 0) 0% ( 0) tMDNS 0x2367cc 0x1b99680 102 0% ( 0) 0% ( 0) tDeviceMgr StartDeviceM 0x10ba658 104 0% ( 0) 0% ( 0) tDiagMgr StartDiagnos 0x10a87b8 110 0% ( 0) 0% ( 0) tJVMLog StartJVMLogT 0x1130db8 125 0% ( 0) 0% ( 0) jFinalizer 0x12a924 0x199bf18 127 0% ( 0) 0% ( 0) Telnet33 StartTelnetS 0x1db6d98 190 0% ( 1) 0% ( 1) tIPConnect StartIPConne 0x1bf5de0 200 0% ( 0) 0% ( 0) tSocketMan StartSocketM 0x110e5e8 245 0% ( 0) 0% ( 0) tInterpreter StartInterpr 0x10c8078 250 0% ( 0) 0% ( 0) tJVMMgr StartJVMThre 0x1140ea8 250 0% ( 0) 0% ( 0) tJvmSpndCkr 0x12a924 0x1969248 250 0% ( 0) 0% ( 0) jOscarDispat 0x12a924 0x1a54600 250 0% ( 0) 0% ( 0) jOscarPackag 0x12a924 0x1a70860 250 0% ( 0) 0% ( 0) jOscarStartL 0x12a924 0x1a87e78 250 0% ( 0) 0% ( 0) jTimerDaemon 0x12a924 0x1ae8918 250 0% ( 0) 0% ( 0) jSWROUTER 0x12a924 0x1afbf58 250 0% ( 0) 0% ( 0) jDA_DeviceAc 0x12a924 0x1b785e8 250 0% ( 0) 0% ( 0) jDDDProc 0x12a924 0x1bdbb48 250 0% ( 0) 0% ( 0) jDDDIPListen 0x12a924 0x1beff18 250 0% ( 0) 0% ( 0) jSessionScav 0x12a924 0x1c70480 250 0% ( 0) 0% ( 0) jThread_1 0x12a924 0x1cf7190 250 0% ( 0) 0% ( 0) jThread_4 0x12a924 0x1d35528 250 0% ( 0) 0% ( 0) jHTTPS_0 0x12a924 0x1d48b88 250 0% ( 0) 0% ( 0) jHTTPS_1 0x12a924 0x1d5beb8 250 0% ( 0) 0% ( 0) jHTTP_3 0x12a924 0x1dc7038 250 0% ( 0) 0% ( 0) jHTTP_5 0x12a924 0x1df4b88 250 0% ( 0) 0% ( 0) KERNEL 0% ( 1) 0% ( 1) INTERRUPT 0% ( 1) 0% ( 1) IDLE 99% ( 950) 99% ( 950) TOTAL 99% ( 954) 99% ( 954) 3 tasks were created. 2 tasks were deleted. NAME ENTRY TID PRI total % (ticks) delta % (ticks) ------------ ------------ ---------- --- --------------- --------------- tExcTask 0x3a1314 0x997c38 0 0% ( 0) 0% ( 0) tJobTask 0x3a222c 0xdd5a30 0 0% ( 0) 0% ( 0) tLogTask logTask 0xdd8d88 0 0% ( 0) 0% ( 0) tNbioLog 0x3a3898 0xddc920 0 0% ( 0) 0% ( 0) tShell0 shellTask 0x1008ac8 1 0% ( 0) 0% ( 0) tWdbTask wdbTask 0xff41b0 3 0% ( 0) 0% ( 0) tSpyTask spyComTask 0x1da0a50 5 5% ( 112) 10% ( 112) tErfTask 0x2b0ef4 0xde0340 10 0% ( 0) 0% ( 0) ti2cTxTask i2cTxTask 0xda0260 50 0% ( 0) 0% ( 0) ti2cRxTask i2cRxTask 0xda2510 50 0% ( 0) 0% ( 0) tNetTask netTask 0xde8d60 50 0% ( 0) 0% ( 0) tXbdService 0x39ce7c 0x100c770 50 0% ( 0) 0% ( 0) tZeroConf-ht 0x241fa8 0x1bad668 50 0% ( 0) 0% ( 0) tFtpdTask 0x2ed0c 0xfedd10 55 0% ( 0) 0% ( 0) tSSHTelnetSv StartSSHTeln 0x1114260 55 0% ( 0) 0% ( 0) tTelnetSvr StartTelnetS 0x112b6d8 55 0% ( 0) 0% ( 0) tDhcpcStateT 0x321be4 0xfe6db8 56 0% ( 0) 0% ( 0) tDhcpcReadTa dhcpcRead 0xfe9420 56 0% ( 0) 0% ( 0) tAxlinkRX StartAxlinkR 0x10ef538 90 0% ( 0) 0% ( 0) tAxlinkTX StartAxlinkT 0x10eb758 91 0% ( 0) 0% ( 0) tICSPIPTX StartICSPIPT 0x10cc828 97 0% ( 0) 0% ( 0) tICSP232TX StartICSP232 0x10d74c8 97 0% ( 0) 0% ( 0) tICSPIPRX StartICSPIPR 0x10d0fd8 98 0% ( 0) 0% ( 0) tICSP232RX StartICSP232 0x10dd9b8 98 0% ( 0) 0% ( 0) jReference H 0x12a924 0x1987318 98 0% ( 0) 0% ( 0) ICSPTCP27 StartICSPTCP 0x1c4bc80 98 0% ( 0) 0% ( 0) ICSPTCPRx27 StartICSPTCP 0x1d64b08 98 0% ( 0) 0% ( 0) ICSPTCP31 StartICSPTCP 0x1d67e88 98 0% ( 1) 0% ( 1) ICSPTCPRx31 StartICSPTCP 0x1c366e0 98 0% ( 0) 0% ( 0) tCypherConnR TaskCypherCo 0x1b63160 99 0% ( 0) 0% ( 0) tCypherI2CRx TaskI2CRx() 0x1b66f18 99 0% ( 0) 0% ( 0) tTffsPTask flPollTask 0xde3ce8 100 0% ( 1) 0% ( 1) tConnectMgr StartConnect 0x10ad928 100 0% ( 0) 0% ( 0) tIPConMgr StartIPConne 0x10e1798 100 0% ( 0) 0% ( 0) tMsgDispatch StartMessage 0x10a49d8 101 0% ( 0) 0% ( 0) tConfMgr StartConfigu 0x10e5578 101 0% ( 0) 0% ( 0) tRouteMgr StartRouteMa 0x10b1708 102 0% ( 0) 0% ( 0) tNotifyMgr StartNotific 0x10b54e8 102 0% ( 1) 0% ( 1) tMDNS 0x2367cc 0x1b99680 102 0% ( 0) 0% ( 0) tDeviceMgr StartDeviceM 0x10ba658 104 0% ( 0) 0% ( 0) tDiagMgr StartDiagnos 0x10a87b8 110 0% ( 0) 0% ( 0) tJVMLog StartJVMLogT 0x1130db8 125 0% ( 0) 0% ( 0) jFinalizer 0x12a924 0x199bf18 127 0% ( 0) 0% ( 0) Telnet33 StartTelnetS 0x1db6d98 190 0% ( 1) 0% ( 0) tIPConnect StartIPConne 0x1bf5de0 200 0% ( 0) 0% ( 0) tSocketMan StartSocketM 0x110e5e8 245 0% ( 0) 0% ( 0) tInterpreter StartInterpr 0x10c8078 250 0% ( 0) 0% ( 0) tJVMMgr StartJVMThre 0x1140ea8 250 0% ( 0) 0% ( 0) tJvmSpndCkr 0x12a924 0x1969248 250 0% ( 0) 0% ( 0) jOscarDispat 0x12a924 0x1a54600 250 0% ( 0) 0% ( 0) jOscarPackag 0x12a924 0x1a70860 250 0% ( 0) 0% ( 0) jOscarStartL 0x12a924 0x1a87e78 250 0% ( 0) 0% ( 0) jTimerDaemon 0x12a924 0x1ae8918 250 0% ( 1) 0% ( 1) jSWROUTER 0x12a924 0x1afbf58 250 0% ( 0) 0% ( 0) jDA_DeviceAc 0x12a924 0x1b785e8 250 0% ( 0) 0% ( 0) jDDDProc 0x12a924 0x1bdbb48 250 0% ( 0) 0% ( 0) jDDDIPListen 0x12a924 0x1beff18 250 0% ( 0) 0% ( 0) jSessionScav 0x12a924 0x1c70480 250 0% ( 0) 0% ( 0) jThread_1 0x12a924 0x1cf7190 250 0% ( 0) 0% ( 0) jThread_4 0x12a924 0x1d35528 250 0% ( 0) 0% ( 0) jHTTPS_0 0x12a924 0x1d48b88 250 0% ( 0) 0% ( 0) jHTTPS_1 0x12a924 0x1d5beb8 250 0% ( 0) 0% ( 0) jHTTP_3 0x12a924 0x1dc7038 250 0% ( 0) 0% ( 0) jHTTP_5 0x12a924 0x1df4b88 250 0% ( 0) 0% ( 0) KERNEL 0% ( 1) 0% ( 0) INTERRUPT 0% ( 1) 0% ( 0) IDLE 94% ( 1899) 89% ( 949) TOTAL 99% ( 2019) 99% ( 1065) NAME ENTRY TID PRI total % (ticks) delta % (ticks) ------------ ------------ ---------- --- --------------- --------------- tExcTask 0x3a1314 0x997c38 0 0% ( 1) 0% ( 1) tJobTask 0x3a222c 0xdd5a30 0 0% ( 0) 0% ( 0) tLogTask logTask 0xdd8d88 0 0% ( 0) 0% ( 0) tNbioLog 0x3a3898 0xddc920 0 0% ( 0) 0% ( 0) tShell0 shellTask 0x1008ac8 1 0% ( 0) 0% ( 0) tWdbTask wdbTask 0xff41b0 3 0% ( 0) 0% ( 0) tSpyTask spyComTask 0x1da0a50 5 7% ( 224) 10% ( 112) tErfTask 0x2b0ef4 0xde0340 10 0% ( 0) 0% ( 0) ti2cTxTask i2cTxTask 0xda0260 50 0% ( 0) 0% ( 0) ti2cRxTask i2cRxTask 0xda2510 50 0% ( 0) 0% ( 0) tNetTask netTask 0xde8d60 50 0% ( 0) 0% ( 0) tXbdService 0x39ce7c 0x100c770 50 0% ( 0) 0% ( 0) tZeroConf-ht 0x241fa8 0x1bad668 50 0% ( 0) 0% ( 0) tFtpdTask 0x2ed0c 0xfedd10 55 0% ( 0) 0% ( 0) tSSHTelnetSv StartSSHTeln 0x1114260 55 0% ( 0) 0% ( 0) tTelnetSvr StartTelnetS 0x112b6d8 55 0% ( 0) 0% ( 0) tDhcpcStateT 0x321be4 0xfe6db8 56 0% ( 0) 0% ( 0) tDhcpcReadTa dhcpcRead 0xfe9420 56 0% ( 0) 0% ( 0) tAxlinkRX StartAxlinkR 0x10ef538 90 0% ( 0) 0% ( 0) tAxlinkTX StartAxlinkT 0x10eb758 91 0% ( 0) 0% ( 0) tICSPIPTX StartICSPIPT 0x10cc828 97 0% ( 0) 0% ( 0) tICSP232TX StartICSP232 0x10d74c8 97 0% ( 0) 0% ( 0) tICSPIPRX StartICSPIPR 0x10d0fd8 98 0% ( 0) 0% ( 0) tICSP232RX StartICSP232 0x10dd9b8 98 0% ( 0) 0% ( 0) jReference H 0x12a924 0x1987318 98 0% ( 0) 0% ( 0) ICSPTCP31 StartICSPTCP 0x1d67e88 98 0% ( 1) 0% ( 0) ICSPTCPRx31 StartICSPTCP 0x1c366e0 98 0% ( 0) 0% ( 0) ICSPTCP27 StartICSPTCP 0x1c4bc80 98 0% ( 0) 0% ( 0) ICSPTCPRx27 StartICSPTCP 0x1d64830 98 0% ( 0) 0% ( 0) tCypherConnR TaskCypherCo 0x1b63160 99 0% ( 0) 0% ( 0) tCypherI2CRx TaskI2CRx() 0x1b66f18 99 0% ( 0) 0% ( 0) tTffsPTask flPollTask 0xde3ce8 100 0% ( 1) 0% ( 0) tConnectMgr StartConnect 0x10ad928 100 0% ( 1) 0% ( 1) tIPConMgr StartIPConne 0x10e1798 100 0% ( 0) 0% ( 0) tMsgDispatch StartMessage 0x10a49d8 101 0% ( 0) 0% ( 0) tConfMgr StartConfigu 0x10e5578 101 0% ( 0) 0% ( 0) tRouteMgr StartRouteMa 0x10b1708 102 0% ( 0) 0% ( 0) tNotifyMgr StartNotific 0x10b54e8 102 0% ( 1) 0% ( 0) tMDNS 0x2367cc 0x1b99680 102 0% ( 1) 0% ( 1) tDeviceMgr StartDeviceM 0x10ba658 104 0% ( 2) 0% ( 2) tDiagMgr StartDiagnos 0x10a87b8 110 0% ( 0) 0% ( 0) tJVMLog StartJVMLogT 0x1130db8 125 0% ( 0) 0% ( 0) jFinalizer 0x12a924 0x199bf18 127 0% ( 0) 0% ( 0) Telnet33 StartTelnetS 0x1db6d98 190 0% ( 1) 0% ( 0) tIPConnect StartIPConne 0x1bf5de0 200 0% ( 1) 0% ( 1) tSocketMan StartSocketM 0x110e5e8 245 0% ( 0) 0% ( 0) tInterpreter StartInterpr 0x10c8078 250 0% ( 0) 0% ( 0) tJVMMgr StartJVMThre 0x1140ea8 250 0% ( 0) 0% ( 0) tJvmSpndCkr 0x12a924 0x1969248 250 0% ( 0) 0% ( 0) jOscarDispat 0x12a924 0x1a54600 250 0% ( 0) 0% ( 0) jOscarPackag 0x12a924 0x1a70860 250 0% ( 0) 0% ( 0) jOscarStartL 0x12a924 0x1a87e78 250 0% ( 0) 0% ( 0) jTimerDaemon 0x12a924 0x1ae8918 250 0% ( 1) 0% ( 0) jSWROUTER 0x12a924 0x1afbf58 250 0% ( 0) 0% ( 0) jDA_DeviceAc 0x12a924 0x1b785e8 250 0% ( 0) 0% ( 0) jDDDProc 0x12a924 0x1bdbb48 250 0% ( 0) 0% ( 0) jDDDIPListen 0x12a924 0x1beff18 250 0% ( 0) 0% ( 0) jSessionScav 0x12a924 0x1c70480 250 0% ( 0) 0% ( 0) jThread_1 0x12a924 0x1cf7190 250 0% ( 0) 0% ( 0) jThread_4 0x12a924 0x1d35528 250 0% ( 0) 0% ( 0) jHTTPS_0 0x12a924 0x1d48b88 250 0% ( 0) 0% ( 0) jHTTPS_1 0x12a924 0x1d5beb8 250 0% ( 0) 0% ( 0) jHTTP_3 0x12a924 0x1dc7038 250 0% ( 0) 0% ( 0) jHTTP_5 0x12a924 0x1df4b88 250 0% ( 0) 0% ( 0) KERNEL 0% ( 2) 0% ( 1) INTERRUPT 0% ( 2) 0% ( 1) IDLE 92% ( 2844) 88% ( 945) TOTAL 99% ( 3084) 98% ( 1065) 2 tasks were created. 2 tasks were deleted.For the average NetLinx programmer, spy is of no use.
It still drops connection when the box is empty (no code).
I find the manager of resources or the spy, the interesting utility. Especially in those cases when АМХ hangs and leads the life that happens... But developers АМХ consider have not worked having written a new code to write to it instructions, with the description of all processes and for what they answer... And the controller all the same hangs after a call of this command. The bulb the status burns constantly does not blink...
