TP4 Edits on Multi-Selections
sonny
Just downloaded the latest version and installed on Win7. I've noticed that I can't edit properties of multiple selected buttons.
Anyone noticed this??
There is an "apply to all" button at the bottom of the properties tab that is set to off on a fresh install of TPD4. Make sure it's on, and you should be fine.
There is an option in the properties window called Apply To All. It is in the lower left portion of the properties window. Have you verified that this is selected?
Jeff -
DHawthorne wrote: »There is an "apply to all" button at the bottom of the properties tab that is set to off on a fresh install of TPD4. Make sure it's on, and you should be fine.
Aha!!! Been on the same computer so long I had forgotten about that.
Thanks guys...
