Autopatch 4YDM errors
vegastech
Does anyone know what these errors mean? I can't seem to find anything in the documentation.
I am getting the following errors when I review the System Errors:
01000004 000000F0
Also, is it possible to disconnect an input/output combination? (I.E., disconnect ouput 2 from input 1, rather than choosing another, unused input?)
01000004 000000F0
Not sure about the error code, but the BCS command for disconnecting is "D"
Here's an example of disconnecting Output 2 on Level 0:
"DL0O2T"
The format is D(Disconnect) L(Level)0(Level0)O2(Output 2)T(Take)
You can also Disconnect an input by replacing "O" with "I" (I=Input)
--John -
To expand a bit further...
if you have one input connected to multiple outputs as in Input 1 connected to Outputs 1,2,3,4,5,6 and you wanted to disconnect output 6 from input 1 you can do two things:
1) "DL0O6T"
or
2) "DL0I1T"
They look almost the same but they do two different things. If you fire off the first command Output 6 will be disconnected, but Input 1 will still be connected to output 1,2,3,4,5. If you fire off the second command, Input 1 will be disconnected and you'll end up with nothing connected to outputs 1,2,3,4,5,6. This is important if you're using the matrix switch to send music to 6 rooms and you only want to disconnect one room. Performing one action will kill the music in one room, the other will kill the music in all rooms.
--John
