Odd NXV-300 Behavior
Been messing around with this device lately. Anyone wander into a scenario where after a master reboot the device id of the nxv-300 changes and no longer matches the DPS of the program? I have it consistently doing it. If I reboot the NXV the device id matches the DPS but if I reboot the master it will take the next number not been used. As an example the DPS is 32001:1:0 when I reboot the NXV and its device id will be 32001. If I then reboot the master the id will be 32002:1:0 and there will be no code for it. Kind of makes this device useless unless you purchase an IP power strip that powers off/on at a master reboot. So much for a cheap virtual panel.
I would think you need to assign it (the NXV) a device number such as 10001. I bet it will keep it then.
http://amxforums.com/showthread.php?t=5755
Thanks for the assist.
