Ace Recert Grading?
I probably shouldn't be posting this but the rules have already changed so what's the harm.
I passed but found the comment regarding the DVD player a little confusing. 4 of the 5 sections failed and then the comment section explained my flaws.
Now lookng at my code I'm wondering what code they were looking at. Am I blind or missing something? Now elsewhere in the system since there are no modules I have a single timeline for checking all Q's which probalby works alright but even if it doesn't the not sending $0D and use of double quotes makes no sense.
ok 5001:3:0 DVD Player 9600,N,8,1
0 Correct use of protocol
0 Proper usage of BUTTON_EVENT for control
0 Proper usage of DATA_EVENT for string handling
0 Feedback (Text/Button)
Notes: You should always encapsulate any command or string sent to a device with string
expressions (double quotations), it is what we teach in class. Also, every string sent to the DVD
player must be sent a terminator of $0D. Since you've not sent this, none of the strings will be
understood by the DVD player.
I guess the test grading queue is not FIFO.
Vining. a win's a win. Congrats on passing! I can only hope I can join you and move my tassle over my hat.
we'll see.
I actually had fun with the virtual keypad and as the user waited for the the system to fully start or shut down I had different strings sent at different intervals letting them know how much longer the need to wait. Please wait..., A little bit longer...., Ok, I lied...., 20 more seconds.., Almost there! I thought of doing a scrolling Santa Claus animation like eric posted prior to christmas but w/ only 3 lines it wouldn't have worked.
I think pride should be on the line in everything we do. Remember when made in the USA meant something.
ericmedley wrote: I think they were just trying to get rid of me quickly but I foiled them.
Yeah I remember, back in the day, when there were only natives.
Nonetheless congrats, it seems that you simply didn't encapsulate your strings in double/single quotes.
- you didn't add the carriage return to your strings ($0D, in this case). (proper usage of protocol)
- you didn't request/use the feedback from the DVD player (i.e. feedback on the play button)
I don't know what you did with button/data_event so I can't answer those. The above seems logical though. Afaik double/single quotes around strings is common sense (at least in other languages).
I hope you're not offended that a newbie is telling you this.
Any way I know the what the eval said but strings are only sent from this function:
I see double quotes and my constant for $0D and although I may be simple, I'm not dumb, well I guess some could argue that, but it is what it is. I just wish I knew what they were looking at. I did return an email to my grader but haven't heard a word and don't suppose I ever will. Makes me think they grade like they write.
