problem with wait command
Need help?
I have a problem with a wait comando on a NI700, and a Rel_230 axlink
When i run the program everthing works fine only after de wait ther is something wrong.
the last 3 comandos dont work. ( switch of Zon 1 to 3)
When i take out the wait it works fine again.
What do i wrong.
Push [vdvMIO_2, 91]//projector off
send_string vdvprojector,"$3A,$50,$4F,$57,$52,$30,$0D" //Power Projector Off
send_command vdvMIO_2,"'Page-Main'"
off[dvIO, 2]
on[vdvMIO_2, 91]
off[dvREL_230, Scherm_down]
on[dvREL_230, Scherm_up]
on[dvREL_230, Zon_richting]
on[dvREL_230, Zon_1]
on[dvREL_230, Zon_2]
on[dvREL_230, Zon_3]
wait 350 //here is the wait and the problem.
off[dvREL_230, Scherm_up]
off[dvREL_230, Zon_1]
off[dvREL_230, Zon_2]
off[dvREL_230, Zon_3]
    	 off[dvIO, 2]
    	 on[vdvMIO_2, 91]
    	 pulse[dvREL_230, Zon_1]
    	 pulse[dvREL_230, Zon_2]
    	 pulse[dvREL_230, Zon_3]
    Try that. I am not sure why the wait would break the functionality, but this should avoid the problem.
    Silly question, but just want to cover the obvious . . . Zon_1, Zon_2 and Zon_3 are all constants, correct? Or at the very least variables, that don't get changed. And to clarify, you do want Zon_1 through Zon_3 to fire immediately and not 35 seconds later?
  • dchristodchristo Junior Member
    You'll need curly braces around the wait if you expect all of those statements to be delayed... otherwise only the first statement after the wait is delayed.
    off[dvIO, 2]
    on[vdvMIO_2, 91]
