Samsung BD-P3600 Pause Command
Does anyone have the IR Hex Code for the pause command on a Samsung BD-P3600? I guess there was an error in the code Samsung sent out to everyone and as a result the pause button does not work. I would learn it, but I don't know what happened to the original remote at this job.
Any help would be greatly appreciated :)
    I don't have the BD-P3600. The closest thing I have is the BDP-1200 and the play and pause commands are both the same. I don't know if this will do you any good but it may be worth a try:
    Play/Pause
    0000 006d 0000 0027 00aa 00aa 0013 0013 0013 0013 0013 0013 0013 0013 0013 0013 0013 0039 0013 0013 0013 0013 0013 0013 0013 0013 0013 0013 0013 0013 0013 0013 0013 0013 0013 0013 0013 0013 0013 00aa 0013 0039 0013 0039 0013 0039 0013 0013 0013 0013 0013 0013 0013 0039 0013 0013 0013 0039 0013 0013 0013 0013 0013 0013 0013 0039 0013 0039 0013 0013 0013 0039 0013 0013 0013 0039 0013 0039 0013 0039 0013 0868
    I got this code and it seems to work:
    0000 006d 0000 0027 00aa 00aa 0013 0013 0012 0014 0012 0014 0012 0014 0012 0014 0012 0038 0012 0014 0012 0014 0012 0014 0012 0014 0012 0014 0012 0013 0013 0013 0013 0013 0012 0014 0012 0014 0012 00aa 0012 0039 0012 0039 0012 0038 0013 0013 0012 0014 0012 0039 0012 0014 0012 0014 0012 0038 0013 0038 0012 0014 0012 0014 0012 0039 0012 0013 0013 0038 0012 0039 0012 0014 0012 0014 0012 0038 0013 0038 0012 0887
    It does pause and play does not pause. To make this a little clearer, the play command that I have (which I think is the same Joe listed) does not pause the movie. If the movie is paused, the play or the pause command will start it playing again.
