NEC Projectors and RS232
I have a new projector which I'm installing. It's a NEC NP500WSG. I used a NEC MT1065 before. From what I can tell the commands are exactly the same as before more or less - however when I send out to the project any command - it just gets reflected back ? See below - any ideas ?
Line 780 (12:18:02):: String To [1:1:1]-[$00$81$00$00$00$81]
Line 781 (12:18:02):: String From [1:1:1]-[$00$81$00$00$00$81]
Ed
Ed
I'd check the wiring first to ensure there isn't a short between pins 2 & 3
On the NP Series I use
"02,$00,$00,$00,$00,$02" to turn the NEC on
"$02,$01,$00,$00,$00,$03" to turn it off
Hope this helps
