Serial control issue with LG 60PS60 Plasma
Just installed an LG 60PS60 in a conference office. Yeah, I know, "Largely Garbage" and all, but it turns out this was the best fit I could come up with for this installation. Until I start testing unit control...
I've got command-response buffering with a currently 3-second response timeout, and what I'm seeing is that every so often, the display simply ignores a serial command. No ACK or NAK, nothing. The next command after a dropped one always works OK.
I've *almost* gotten rid of the problem by adding some additional wait before sending a next command. I've tried both a half and full second delay after receiving a response from the display. I can't tell any different between the half and full second waits, but it does get worse if I take that wait out completely.
I still get dropped commands occasionally and randomly, and I can consistently reproduce a dropped command if I send commands in a specific order: Set Input 1 (CATV), Set Channel, Set Volume, Set Aspect. If the first 2 are in that order, it will consistently drop the 3rd command no matter what it is.
I'm getting around this by re-issuing dropped commands, but that with the built-in wait makes the switching seem really slow and clunky.
Any advice?
Thanks!
Any advice?
Thanks!
Another thing, see if you're using the right baud rate, in another LG Plasma, the manual says 9600, but I used 115200,n,8,1 and works fine.
Good ideas, I haven't tried either. The manual does specifically say 9600,n,8,1,n; I would have tried another baud rate but I can't find the setup for the serial port in the menu.
But if in 9600 is replying that's ok
Interesting. When I very first hooked up to it, I got all $F0$FF crap back too. But I thought my cabling was tweaked so I had a round of re-terminating the serial before I finally got a good response off the serial. I wonder if my cable was OK the first time, and if I had jacked it up to the higher baud it might have worked?
Curious.
